quick radiator / coolant refill question
Old Aug 26, 2009 | 11:40 AM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
did i do this right? and now what?
heater core went, drained the radiator & bypassed the heater core.
filled the coolant back up. it only took about 8 quarts instead of the 14quarts the manual says but i guess this is from A it being raised in the front when i drained the radiator and B there’s no longer a heater core?
i waited for it to warm up, the coolant level dropped and i topped it off, put the cap back on and now it’s sitting. Do i wait for it to cool and check the level again, it should be at the top right?
Also i miss placed.. the coolant reservoir cap... is this important or can i put duct tape over it. lol
Old Aug 26, 2009 | 11:52 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: quick radiator / coolant refill question
If duct tape isnt working, youre not using enough of it. ha. But need a 16lbs rated vented Radiator Cap. You should have a overflow Rez. Its best to premix the coolant and distilled water b4 adding also. I usually fill to top. start car, wait until the top radiator hose gets hot, while continually topping off for like 8 minutes, if it starts overflowing-then cap it youre done. fill the rez half way, done. to check wait until it cools, then repeat the process. check weekly.
Old Aug 26, 2009 | 12:36 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
damn it, question about bypassing now. do i have to have the two hoses that go in the heater core connected to bypass it or can i just plug them? the bypass i did connecting the two failed and it leaking now
Old Aug 29, 2009 | 11:37 AM
na you cant plug them. theres a barbd connector you can get at Home depot that is a male to male. with some clamps you should be ok. I was going to use it on my throttle body bypass.
Old Aug 29, 2009 | 12:37 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Actually you can plug them.
Old Aug 29, 2009 | 12:43 PM
im cool and all, and am not bashing on your text. but if you plug them then the pressure would be too servere. i believe its better to bypass, he already has coolant going through his tb. yes you can plug them you win.
Old Aug 29, 2009 | 12:53 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
What pressure too severe? Instead of going through heater hoses it just goes through the cooling system.
Old Aug 30, 2009 | 12:28 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
can you possibly give me a link to what you're talking about on home depot, i tried looking but no success. it seems easier to just bypass it but even that is turning into a bigger project than i thought.
Old Aug 30, 2009 | 01:21 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
To bypass: take the hose coming out of the intake off, and put the opposite end of the hose coming from the water pump on to the fitting on the intake. Make sure you don't forget to tinghten the hose clamp down.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
