90 firebird carb problems
Old Aug 27, 2009 | 12:46 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
The injectors or something is clogged inside of the thottle body and i need to clean it. What should i use and where can i get the gasket set? Its a rochester 17064317. I tried Advance Auto Parts and online but i cant find it.
Old Aug 27, 2009 | 01:51 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 90 firebird carb problems
If you've got injectors, its not a carb .
Moving along, if there are 2 injectors in a carb-looking unit, you've got a throttle body injected setup on your car. Since it sounds like Advance is local to you, the kits you'd want to look at would be:
Complete overhaul kit
Injector service kit
Hope this helps
Old Aug 27, 2009 | 02:03 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
IF you have a timing light available, hook it up and point it towards the injectors while running (if it runs at all). You should see a conical shape spray pattern ( even spray on both sides W/out any drips). What makes you think you need a rebuild kit? What symptoms is your car having?
Old Aug 27, 2009 | 09:54 PM
jjh011794's Avatar
Car: 90 Firebird
Engine: 5.0L
Well the car start for like two seconds and then dies so i thought thefuel filter was clogged so i replaced that now it is doing the same thing so i pulled the line off the throttle body and checked the fuel line and that has a good flow so i think that it is clogged injectors so im hoping that i can clean them and not have to buy new ones. And thank you for the links. that is perfect. im going to advance tommorow to get the overhaul kit.
Old Aug 27, 2009 | 10:25 PM
southbay08's Avatar
before you purchase new injectors, and you do not have any luck with the overhaul kit, we can clean and flowtest them for you. Alot cheaper than buying new ones
info@southbayfuelinjectors.com
jhawkeye
May 25, 2022 06:33 PM
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
zeitghaist
Aug 18, 2015 07:33 AM
