car not getting the right spark **UPDATE**
Old Aug 29, 2009 | 06:28 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
I just recently dropped a 350 into my 84 trans am and the first day i went to sart it, it was running good didn't let it run long beacause of the water pump not being hooked up. had it running 3 times that day and it sounded fine. two days later it just turns and turns doesnt even trie to fire up. took a plug wire off stuck a screw driver in it and put it to ground and it gets two sparks and dies no more spark. if you turn the key off and then trie to start again it does same thing couple sparks then nothing. we tried 3 different modules, 2 different caps, rotor and coil. also a new disstributor. and same thing. What is going on here. my neighbor and i are fresh out of ideas. the only thing that was done since the first time it was running i hooked up some gauges inside the car. supposed to hook them up to a 12v switched sorce so there was a plug just hanging under the dash that was not pluged into anything. So i have no idea. Oh there is like 3 wires that come off the starter and go to the inside on is cut and never been used since i got the car. we took that wire and went dirrectly to the distributor and that didnt. help either. any suggestions would be great.
Old Aug 29, 2009 | 06:31 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: car not getting the right spark
are you sure the rotor is turning?
Old Aug 29, 2009 | 06:42 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
when i turned the motor by hand to make sure it wasnt off time it was turning.
Old Aug 29, 2009 | 06:49 PM
Car: 91 RS
Engine: 350 vortec
just checking as you have pretty much replaced the entire dist twice there... wouldnt assume both were bad next i would say you arent getting power to the correct terminal on the dist
Old Aug 29, 2009 | 06:53 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
i got the wires that come out of the bottom of the dis. to the back part of the cap cant put those in wrong. the pink wire to batt. and brown wire to tach. could i not be getting enough power.
Old Aug 30, 2009 | 09:24 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
well i got it running. I unplugged the tach wire for s***s and giggles and it started right up. What is up with that is it becuase i had the headlight and dimmer switch out.
Old Aug 31, 2009 | 12:01 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
tach wire has to do with the coil, prolly have a grounded tach on the dash
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
