ac problem
Old Aug 29, 2009 | 08:18 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
ac problem
okay guys quick question of what i should check or what you think
my ac is warm or acts as if im over heating when driving. if im not stopping and going it stays some what cold. filled with freon today and still same results.
and with ac it over heats. with it off not a problem and yes both fans are on when they should be.
im stumped
Old Aug 29, 2009 | 11:54 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: ac problem
Are you able to check high and low pressure together?
You may have air in the system and it may be over pressured at idle.
Just guessing but sounds logical.
Old Aug 30, 2009 | 11:40 AM
Car: 90 formula
Transmission: auto
Re: ac problem
were going to check the pressure ether tonite or tomorrow.
Old Aug 30, 2009 | 09:25 PM
Car: 90 formula
Transmission: auto
Re: ac problem
was over charged. brought it down where it should be. was cold as hell til i drove it and sat in it and then it started the whole thing of warm cold warm again.
dad suggests pump it out and recharged it. i don't think it will help but what else should i check or do?
Old Sep 6, 2009 | 09:33 AM
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: ac problem
why do you not think it will help?
At least it will confirm that you have no air in there and you can take it from there.
I'd get some leak detector in there too if I was you. That way you can monitor connections easier seeing as there will be luminous green around a bad one with leak detector.
what sort of frequency is your compressor clutching....constant or short bursts?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
