Noise in valve train
Old Aug 30, 2009 | 10:21 AM
blackroc68's Avatar
I installed a comp 280 xfi cam on my smallblock 383 chevy.The motor has etec 200 heads(springs good to 600 lift)18ccdish pistons3.75rods.I was running a TPIS zz9 cam 515/555 lift on 112 base circle.NOw i have a comp 280xfi on a 113 with 576/571 the duration is 230/236 at 50.The cam calls for beehive springs comp part#26986-16. To start the motor i used the stock Etec 200 springs.I tried Adjusting the rockers I tried everything from 1 half turn to 1 full turn from ZERo lash.The motor runs good,At idle i have no noIse but when i rev it i here a loud tapping right under my intake.With the zz9 i had no valvetrain noise> im stumped IT cant be the lifters can it
Old Sep 1, 2009 | 07:22 AM
blackroc68's Avatar
Re: Noise in valve train
Anybody?
Old Sep 1, 2009 | 05:32 PM
ljnowell's Avatar
If your valvesprings dont have sufficient pressure you can bounce the valves off the seats. This causes all kinds of valvetrain noise.
Old Sep 2, 2009 | 07:32 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
If you figure this out, let me know... I have an XFI268 and I've adjusted my Comp Cams Magnum rockers (roller tips) several times and the chatter won't go away.
gta892000
Aug 11, 2019 11:16 AM
drptop70ss
Oct 4, 2015 09:44 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Randomtask2
Sep 7, 2015 05:06 PM
