671 Blower
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 671 Blower
You could if you really underdrive it to stay below 5 pounds of boost.
A proper blower engine needs a lot of good internal parts and low compression, forged pistons to survive. Building an engine for a blower is no different than building an engine for a turbo or nitrous. A stock engine can handle a small amount of increased HP but it really needs to be built to handle a lot of HP that these power adders can provide.
Car: 87 IROC L98
Re: 671 Blower
You will need a Chev blower manifold. Small distributor. You also need a SBC blower drive mandrel for the crank. Probably a different length belt. Being used, the blower probably needs new strips.
You'll be better off just buying a complete kit specific for your engine instead of trying to piece together a used system. A complete kit is around $4000. Just add carbs and linkage.
codeysabatini
Nov 10, 2015 04:07 PM
buckeyecelt
Sep 24, 2015 05:50 AM
