1985 firebird stalling problems.
Old Sep 3, 2009 | 07:56 PM
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Ok so my stalling problem has been getting worse and worse. And I have no clue what it is. Its quite frustrating. My car is a 1985 fuel injected 2.8 V6. When i bought it the RPMs were around 1,200 for idle and it was during the winter. Now during the summer the RPMs are around 1,500. And my car constantly stalls at stoplights. I litterally have to keep my foot on the gas and the other on the brake to keep it going. If I dont the idle will drop down to 400RPM and stall out on me. I also checked for vacuum leaks and there doesnt seem to be any. Any ideas of what it might be?
Old Sep 3, 2009 | 08:52 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: 1985 firebird stalling problems.
try adjusting idle and a lot days the fuels being processed and the cheaper get out there, perhaps the fuel filter? i had the same problem with stalling, even bought the car as stalling at every stop. i didnt know much about cars then, but i just used fuel NOS fuel injector cleaner, but i found out that changing the fuel filter made it better.
Old Sep 3, 2009 | 08:56 PM
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Ive tried messing with the idle and it didnt help. Ill try to replace the fuel filter tomorrow if I have time. Thanks,
Old Sep 3, 2009 | 09:01 PM
you got to do a certain process to do the idle, your going to have find out, i lost my book. haynes i recommend
Old Sep 3, 2009 | 09:53 PM
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
I already looked it up. You have to disconnect the oxygen sensor, and do the whole process. Ive already done that though. It didnt help any.
Old Sep 4, 2009 | 11:11 AM
GregC's Avatar
Sounds like a vacuum leak, but you mention that you already checked that. 1500 rpm is pretty high for idle speed. Is the IAC working?
Old Sep 4, 2009 | 02:40 PM
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Ive already checked for vacuum leaks, there arent any and I had 2 shops look at it and cant seem to figuire it out. Ive tried to set the idle to 800RPM but it will die if it goes anywhere near 700rpm on idle. The IAC is deff working also. It tries to correct itself but when it gets below 800 the engine will die.
jklein337
Sep 19, 2018 06:23 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
