Where is number 1 on a TBI/TPI small cap distributor?
Old Sep 5, 2009 | 05:36 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I have two different caps with not much of a reference point. The one in this pic, just says 8 right in the middle.
I installed the distributer as shown where my finger is pointing. Is this number 1 firing? I position the rotor where I think it should be. Is this correct.
I know they can be made to work any way. I just need to know if this is the correct position for when I drop it in after finding TDC? (this is a spare) I currently have another dizzy in there.
This is in my truck with TBI . I installed a engine and am having a big problem getting the timing right. Once I know for sure where number 1 is, I can route the wires correctly based on the firing order no problem.
Attached Thumbnails Where is number 1 on a TBI/TPI small cap distributor?-picture-067.jpg   Where is number 1 on a TBI/TPI small cap distributor?-picture-068.jpg   Where is number 1 on a TBI/TPI small cap distributor?-picture-069.jpg
Old Sep 5, 2009 | 05:37 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Re: Where is number 1 on a TBI/TPI small cap distributor?
Please pay no mind to the condition of the cap and rotor. I have new ones on it.
Old Sep 5, 2009 | 06:09 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
number one can be any of those terminals not important which one only thing you need to know is which one of those terminals the rotor points at when its should be fireing 1 to start routeing your plug wires
Old Sep 5, 2009 | 08:17 PM
polaris91's Avatar
Car: 88 camaro z28
on my 88 tpi it is the one that your nuckle is partialy covering not on the finger your pointing with but the one next to it
Old Sep 5, 2009 | 08:40 PM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Turn the motor around to TDC, number 1 firing position. Whichever terminal the rotor is pointing at is number 1.
1992 Trans Am
May 10, 2023 07:19 PM
junkcltr
Aug 2, 2019 11:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
