oil leaking from mechanical fuel pump?
Car: 1984 Camaro Sport, 1985 camaro
Engine: 305 v8, v6
So ive been having this really bad oil leak and have started changing all the gaskets and thought i was done. then the next day theres no oil in the car and its all over the floor so i put oil in and revved the engine and it seemed to be coming from a little hole on the fuel pump. any ideas why its doing this?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: oil leaking from mechanical fuel pump?
Looks like the "sofakingdom" leak. Is there a bolt in the top accessory hole where the smog pump was mounted? Can't tell for sure from the pic. That bolt hole goes into the fuel pump bore and should be plugged with a short bolt when the pump is removed.
Engine: 305 v8, v6
Ive got those plugged up, but im curious to know if the bolt was to long and got pushed in to far could that cause the oil to go through the back of the fuel pump?
If the bolt's too long it will bind the fuel pump push rod. You may want to pull yours off and check it and the gasket. A replacement fuel pump should be under $20.
http://forum.grumpysperformance.com/...hp?f=51&t=2111
this should help
this should help
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
