PUSHROD LENGTH HELP
Old Sep 14, 2009 | 12:37 PM
SanFranCyco's Avatar
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
PUSHROD LENGTH HELP
Still trying to figure out what length pushrods should i use for a stock TPI 5.7 cam,1.6 roller rockers and cast World sportsman II heads.The pushrods I'm using now are comp cam stock length but they seem to be a little far foward on the valve stem.I dont have a pushrod length checker and was wondering if someone would know the length i need with the parts i have.any help will be appreciated.
Old Sep 14, 2009 | 03:30 PM
grumpyvette's Avatar
Re: PUSHROD LENGTH HELP
you need to measure not guess!
http://forum.grumpysperformance.com/...6&p=3033#p3033
Old Sep 15, 2009 | 02:05 PM
Car: 87 GTA
what do i need and need to do to measure the length
Old Sep 15, 2009 | 03:31 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
A pushrod length checking tool can be bought at many of the on-line sites, like JEGS and SummitRacing.
From what you described, you have the correct length pushrods already. You can check CompCams' website for diagram on how the roller tip of the rocker arm should look.
Outboard, centered, inboard, centered and outboard is the movement that's recommended.
Hope this helps.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
Old Sep 15, 2009 | 03:43 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
The rods you have should be fine......oriellys has an adjustable pushrod to check the length if you are worried......they also have chromoly hardened pushrods for cheep as well if ur interested.
Old Sep 16, 2009 | 12:02 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Get an adjustable push rod and check for yourself. They are not very expensive, and you'll know you have the correct size.
http://www.circletrack.com/techartic...gth/index.html
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
