Can anyone ID this cam? 156 cpc bc 15
Old Sep 24, 2009 | 01:22 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Hi fellaz. Im back. Can anyone help me ID this camshaft? Its a stock GM for the 350 block. The cam is a rollar cam. the only stamps on it are 156 cpc bc 15 . Does this number look familiar to anybody? Ive searched the whole web and I cant find anything. The only other cam that comes close to this cam is 155 cpc bc 15 which is the LO3 cam i believe. Thanx guyz.
Old Sep 24, 2009 | 10:13 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Can anyone ID this cam? 156 cpc bc 15
those numbers are absolutely worthless, and similarities mean nothing. The first clue will be whether or not is has a lobe for a fuel pump. If so, it's a performance cam, if not, it's a production cam. From there, you'll need to use a cam degreeing kit to figure out the specs. Just 2 weeks ago I detailed how to do that.
Old Sep 24, 2009 | 02:11 PM
Atilla the Fun, Whats up. Yes it does have a mechanical fuel pump lobe. The cam came out of this block here
14093638 1987-95 350 4-bolt mains Roller with a 1 piece rear seal.
The issue lies here. We all know that the 86 IROC-Z came out with a 305 LB9 engine. So when I threw a rod, out of curiosity I ran the casting and found out that the block is a 350. So the previous owner had swapped out the 305 and slapped in a 350. So now that I got another 350 (the same exact block as the one I broke), I wanted to know the specs so that I can buy a new cam with the same exact specs because this old one has damage from when the rod disenigrated. So then it must be a performance cam then. Do you have any suggestions to a stock type after market cam. I want to stay stock because I cant afford to tune the ECM at a Dyno shop.
Old Sep 24, 2009 | 10:23 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
WRONG.... The 156# tells me ALL I need to know. 156 one of the L98/LB9/9C1 L05 camshafts.
Old Sep 25, 2009 | 09:09 PM
Cool thanks, but can you possibly ID this cam, the casting is 155 FM65 206 99L. Here is the link to see the cam its line 15
https://www.thirdgen.org/forums/tech...lp-please.html
Old Apr 25, 2018 | 10:43 AM
Bills87IROC's Avatar
Sent you a PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
