Electronic spark control module -- where?
Old Sep 26, 2009 | 07:06 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys, i am pulling code 43 on my car and alldata says something different than what the list of trouble codes here on the site say. Alldata says code 43 is ''Electronic Spark Control (ESC) retard signal for too long a time. causes retard in EST signal''...
it has troubleshooting tips but i dont know where the ESC is so I can't troubleshoot. The only thing i am pretty sure of is that it is not the same as the ignition module in the distributor. Any help would be appreciated.
Old Sep 26, 2009 | 07:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Electronic spark control module -- where?
it's a black plastic module over by the brake booster,the
module is about 2 1/2" square by about 5/8" thick with
a 5-pin plug,it's on a metal bracket with the vac sensor
and some relays.
Old Sep 26, 2009 | 07:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The knock sensor is located in the right hand drain hole in the engine block. Right in front of the stater.
The knock filter is near the brake booster behind the relays. Black plastic module about 3 x 3 x 1/2" in sizes.
RBob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 9, 2015 09:09 AM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
