Overheating problem! HELP!
Car: 92 RS
Engine: 305 5.0L V8
Transmission: 4-speed Auto
My 92 RS is overheating for some reason. Replaced the radiator and coolant temp sensor. It isn't leaking at all but still overheats. Any suggestions?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Overheating problem! HELP!
fans coming on?
did you replace the rad cap?
have the air dam under the car?
replace thermostat?
check for leaves and trash inbetween the radiator and a/c condensor?
replace thermostat?
