Howling noise?
Old Sep 29, 2009 | 12:56 AM
IROC-Zach28's Avatar
Car: 87 IROC-Z
Engine: 5.7 350 TPI
Howling noise?
So sometimes my car makes this fairly loud howling noise that seems to come from the rear. It happens often when I am low on gas and make a turn, but have noticed it a couple times while doing some city driving and I will have plenty of gas. Has anyone had this problem before? Any ideas what it could be? I was thinking it could be the fuel pump, but it is fairly new...
Old Sep 29, 2009 | 06:42 AM
WSX123's Avatar
Car: 1988 Trans Am GTA
Re: Howling noise?
does it seem to do it more at night during a full moon jk
fuel pump was what i was thinking too, even though its new maybe its defective in some way.
Old Sep 29, 2009 | 07:01 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Howling noise?
Rear tires in good shape?Gear oil up to full level or need replaced?
Old Sep 29, 2009 | 02:17 PM
Car: 87 IROC-Z
Engine: 5.7 350 TPI
Re: Howling noise?
I haven't checked the gear oil. But the tires are in good shape, a few months old. I will check out the fuel pump, but maybe my car is just part werewolf lol
Old Sep 29, 2009 | 05:06 PM
Towman84Z's Avatar
Re: Howling noise?
might be the rear itself, check the gear oil
Old Sep 29, 2009 | 05:12 PM
teega's Avatar
Car: 90 Pontiac Transam
Re: Howling noise?
I've just gone through four AC Delco fuel pumps. Three of them howled or sang. They are junk. When the tank is dry as you probably know the pump does not get lubrication. Once it's gone it doesn't matter whether or not you have gas in the tank. Buy any other replacement pump other than Delco.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
64Chief
Sep 12, 2015 08:05 AM
Randomtask2
Sep 7, 2015 05:06 PM
