Fuel smell, no idea where its coming from?
Old Oct 6, 2009 | 07:07 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I recently noticed a fuel smell coming from my car. It seems to be coming from the rear of the car.
I have checked EVERYTHING fuel related (injectors, FPR, fuel lines, fuel filter......)to check for leaks and cant find anything out of the ordinary?
The car runs perfect. No miss or anything that would make me think there is a fuel related problem.
Its only after I shut the car off I smell it.
When the car is cold, I dont smell it at all.
The only thing I can think of is fumes escaping from the gas cap? How would i check that. Ill probably just replace it, but was looking for other ideas on what could be creating this smell.
Old Oct 6, 2009 | 10:08 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Fuel smell, no idea where its coming from?
Check where the filler neck attaches to the tank.
Old Oct 6, 2009 | 10:37 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Good call! I didnt check there. Ill check when i get home from work.
Funny you mentioned this, my mom needed the filler neck replaced on her 2002 Dodge with 82K on it. They said it was dryrotted.
Old Oct 6, 2009 | 10:45 AM
Twin_Turbo's Avatar
Yes, wanna bet it's the filler neck, the soldering on mine broke because some prev. owner most likely used to lean on the filler nozzle whilst filling up. Willing to bet you have the same problem. Especially when filling it all the way up the fuel smell was horrendous.
fixed
Now I gotta say, that's some crappy soldering from the factory right there, especially on a part that is susceptible to stress because of people hanging on the filler nozzle...surely GM could have come up with that.
Old Oct 6, 2009 | 01:43 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
I take it i got to pull the tank to fix it? DAMN.
Old Oct 6, 2009 | 04:03 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
i had a similar problem and it was due to raw gas not getting burned in my cat cause it was bad. i changed it out and it was fine. just a suggestion
Old Oct 6, 2009 | 05:22 PM
Twin_Turbo's Avatar
You shouldn't have raw gas burning in your cat con period, unless you want to torch the carpet that is.
Old Oct 6, 2009 | 05:40 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
A buddy of mine(WileECoyoteSr.) had the same funny smell. It turned out to be the rubber fuel/vent lines at the gas tank, they were old and had cracked. When you take down your tank to check the filler neck weld, check the rubber lines too!!! Those lines are a lot cheaper to replace then the tank
Old Oct 9, 2009 | 04:47 PM
Car: 87 T-Top GTA
Hey Camaro1185, any updates......?
Old Oct 9, 2009 | 06:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
there is a factory safety recall on some year tanks . i don't recall years , try a search on tank recall . you may get it fixed free . good luck .
Old Oct 9, 2009 | 06:58 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Nope no updates yet. I wont have time to pull the tank until probably the spring.
Not only that, my car hates to be on jack stands, i posted a while back about my "near death experience" with my current jack stands, and have been a little bit afraid to get back under the car. Long story short, if i had not left my floor jack slightly supporting the "pumpkin" as just a precaution i wouldnt be writing this right now.
That would be so cool if i get the tank replaced for free, that would mean i wont have to get under the car!
Old Oct 16, 2009 | 06:15 PM
belzbug's Avatar
Car: 87 T/A, 72 AMX, 05 Bug, 06 Tundra
Engine: V-8's, 4 Banger/Turbo
Transmission: All AT, Bad Knees
Hi Guy, Did you ever get your gas smell fixed? I have a 87' TA with the same problem. Can't find a leak anywhere!!!, Replace the charcoal cannister, no help. THANKS...belzbug in TN MY tsam be
Old Oct 16, 2009 | 08:40 PM
Car: 87 T-Top GTA
where is the smell coming from??? (Form the front of car OR rear end of car).... And start there!!!
Old Oct 16, 2009 | 08:42 PM
Car: 87 T-Top GTA
So have you even looked into whether or not your tank is part of that recall yet??? (Why Wait Until Spring To Find Out????)
Old Oct 16, 2009 | 09:01 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
The 2 things I would check would be the filler neck were it attaches to the tank, as others have noted, and the vent line. Also check to make sure the vent isn't clogged or stuck. The cause of the crack at the neck is usually from people trying to shortcut a fuelpump job and not removing the dif, like you're supposed to do. About the recall, I believe it was only for 91-92 camaros and recalls do expire, so even if there was a recall it's very likely that it has expired being that our cars are over 20yrs old(if not older).
Old Oct 17, 2009 | 01:19 PM
Car: 87 T-Top GTA
You maybe very well right on that, 91 is included on that recall! And it has NOT expired yet(if they do?). A friend of mine WileECoyoteSr just did the recall on his,(about 3 weeks ago). The neck was still good, but the rubber lines from the tank were old, cracked, and leaking gas.
Old Oct 22, 2009 | 08:05 PM
bgood71's Avatar
Car: 89 GTA
[I] had time to research the recall on alldata today at work.It is for 91and 92 camaros, and it is a lifetime recall. It said to do the recall regardless of time or ownership. I wonder if gm still has oe tanks or would they use aftermarket since they stop making parts ten years.
bryan623
Mar 22, 2021 06:43 PM
pimp2303
Jul 27, 2017 02:03 PM
Fast355
Dec 2, 2016 06:33 PM
Kaweh
Aug 9, 2015 02:54 PM
