high idle/ black exhaust smoke
Old Oct 6, 2009 | 11:24 PM
84transam87's Avatar
84 trans am 305 4brl carb. A/T. car was idling like crap when cold then once warmed up would idle real high and then diesel once turned off. i found that bolts on carb were loose and tightened them up. made a big difference but i still get black smoke from the exhaust and the idle when warmed up is really high and will actually accelerate my car without any help. once in park the idle is very high at about 1500 or more. i looked over the forums and didnt really find anyone with similar problems and or no reponse to say how it was fixed. car was sitting for 4 years before purchased but has had a tune up minus oxygen sensor. PLEASE HELP!!!!!!!
Old Oct 7, 2009 | 01:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sure sounds like the choke isn't opening up.
Old Oct 7, 2009 | 03:02 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: high idle/ black exhaust smoke
Either your choke is stuck or your carb needs a rebuild, which would probably be a good idea anyway.
Old Oct 8, 2009 | 01:30 AM
taking it to shop friday to have it timed and the carb looked at...thanks!!
Old Oct 16, 2009 | 03:54 PM
i see a lot of threads where no one posts what the actual fix was so here is my fix for this issue. the choke was the main issue. it was getting power but not working properly. the other issue had something to do with a purge control for the carb. i forget what it was called. car now runs a whole heck of a lot better...THANKS EVERYONE!!!
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
diana227vegas
Jul 8, 2016 12:27 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Fronzizzle
Aug 17, 2015 02:52 PM
