Fully Roller 350 out of a 97 Pickup
Old Oct 8, 2009 | 10:44 AM
SLOWMARO355's Avatar
I want to install this cam. Would I have to change my pushrods?
Small Block Chevy 262-400 Hydraulic Camshaft
COMP CAM EXTREME ENERGY 268
Great for street machines, largest cam for stock converter, better with 2000+ stall.
1600-5800
12-242-2
XE268H
268
280
224
230
.477
.480
110°
Old Oct 8, 2009 | 10:54 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Fully Roller 350 out of a 97 Pickup
yes, and you would have to change the lifters, because that cam is for non-roller lifters. You'd do better with the LT4-HOT cam.
Old Oct 8, 2009 | 11:20 AM
I like the choppy idle of the 268, and it comes with lifters
Old Oct 8, 2009 | 05:04 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
yes, and you would have to change the lifters, because that cam is for non-roller lifters. .
And a new timing set to suit the flat tappet cam
Old Oct 8, 2009 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by SLOWMARO355
I like the choppy idle of the 268...
Is that the sum of your goals?
To summarize the answer to your original question, roller lifter push rods are shorter than flat tappet push rods, so you'd need a new set.
Old Oct 14, 2009 | 04:21 PM
Will that cam work good with An edelbrock rpm intake? I have a 600 holley, 906 heads.
Old Oct 14, 2009 | 07:23 PM
five7kid's Avatar
An Edelbrock Performer RPM Vortec intake, yes.
Still wondering why you're downgrading to a flat tappet cam.
(Also wondering why you quoted my previous response, since what you asked next didn't have anything to do with what I said.)
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
Eric-86sc
Aug 24, 2015 09:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
