Engine wont run after swap
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
hey guys, my trans mission went in my 89 rs, so i pulled the old 305 and put a new t5 and a 350, wired it all back up but when i go to turn it over nothing happens, no clicking noise, i believe its the starter? or could the wiring be playing a problem. Put battery on a charger for 3 days and nothing. First engine swap and stumpt.
TBI setup
350 truck motor
5 speed
TBI setup
350 truck motor
5 speed
Transmission: 4L80E/4L80E
The starter safety switch is on the shifter for automatics, and clutch for manual transmissions. Did you redo that wiring?
Engine: 355 chevy
Transmission: t-5
Re: Engine wont run after swap
it was always a 5 speed car just 305 tbi and i had a 350 tbi and just switched it over but i was tinkering today and i got the starter able to turn over but wont turn over the motor,i think i have some wire issues i have to deal with thanks for the imput
theshackle
Mar 5, 2017 06:37 PM
