New starter, good batt, won't start, no lights, HELP
Old Oct 10, 2009 | 06:27 PM
airbrushguy's Avatar
'86 305 auto....Son had car, ran rough, stalled , said he saw smoke, couldn't start, got towed.
Car had hard click and dome light worked, but wouldn't crank.
Replaced starter and now I have no click, no nothing, not even lights! Not even dome light. Any idea what I screwed up?
I placed two wires onto starter on same post as battery cable goes on and light weight wire on small stud nearest engine. Did all this with battery disconnected, then reconnected battery and...nothing.
Does not seem like any fuses are gone. Any ideas?
Old Oct 10, 2009 | 06:39 PM
Polo_Green92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock Open Rearend
Re: New starter, good batt, won't start, no lights, HELP
have u checked ur relays? also have u checked all the cables goin to the starter to make sure they weren't exposed wires loose nuts or bolts and there wasn't any corrosion on them? also may have a good batt but no juice?
Old Oct 10, 2009 | 07:01 PM
Which relays...where are they?
Old Oct 10, 2009 | 07:18 PM
crash71's Avatar
Car: 1989 camaro rs 2.8l a/t
check fusiblelinks at starter ,most of thems have about 5 links. You can usually pull A bad one apart with your fingers.
Old Oct 10, 2009 | 07:27 PM
Links look good.
Old Oct 10, 2009 | 07:47 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
i believe that there are some fusible links close to the battery to check as well. you really need to give them a tug. lookin good isnt a good diagnosis. pull on them. get a test light and check the fuses for which has power (key on and key off) and which ones dont-it will start to steer you in the correct direction.
Old Oct 11, 2009 | 03:37 AM
Car: 1992 Camaro RS
Engine: 305 TBI
sorry scratch the relays I forgot there isn't a relay except the fuel pump relays on the firewall that was my fault on the relays
Old Oct 26, 2009 | 06:51 PM
TTT
Old Oct 26, 2009 | 07:55 PM
run a jumper wire from the solenoid start terminal up to the battery and try touching the battery positive terminal. by doing this you will take alot of wiring out of the loop and will see at least if you have good juice to the starter. make sure its in neutral if it is a manual tranny.
Old Oct 26, 2009 | 08:21 PM
The solenoid start terminal is the small terminal?
Old Oct 27, 2009 | 03:41 PM
if your solenoid is equipped with just a main battery (large terminal) and a start (small terminal) it is indeed the small terminal. some solenoids have an "r" terminal as well. for a total of 3 terminals. you want the small terminal closest to the block. with a flashlight you should see a small "s" molded into the solenoid as well.
Old Oct 27, 2009 | 05:20 PM
MetallicaWolfe's Avatar
Car: 1986 Berlinetta Camaro
Engine: 350 SWAP
Axle/Gears: Stock
You check your wiring that goes up to the starter? I once had a problem where nothing worked and eventually found out it was a busted wire down going down to the solenoid and starter sucked bad...took over a month for me to figure it out...XD
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
86Base
Aug 8, 2015 01:34 PM
