STIFF GAS PEDAL- ANY IDEAS???
Old Oct 11, 2009 | 09:37 PM
rickys69charger's Avatar
Car: 1985 chevy camaro
Engine: V8 305 5.0
Hi, i have a 92 RS and the previous owner swapped out the v6 for a 350 V8 and for some reason the gas pedal is really really stiff. what can i do??
thanks
Old Oct 11, 2009 | 10:05 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Re: STIFF GAS PEDAL- ANY IDEAS???
Disconnect the throttle cable from the throttle linkage and then you can work the throttle linkage/valve by itself on the tb as well as working the cable to the gas pedal itself.
If the linkage itself is stiff, lube it up and make sure the throttle blades arent dragging, if the stiffness is from the cable/pedal, its probably your cable but you could lube any moving parts on the pedal assembly to see if that helps.
Old Oct 11, 2009 | 11:46 PM
walrus108's Avatar
Car: 1989 GTA White Hardtop
Axle/Gears: 9 bolt 3.27
I ran into this problem once and it was as simple as having an improper throttle return spring installed. Remove the spring, with the car off of course, and see if the pedal moves freely. If so, the dealer will have the right spring pretty cheap.
Old Oct 12, 2009 | 05:32 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
If the P.O. converted it to a carbureted setup, it might be using dual return springs, which can be quite stiff. Removing one will soften the feel. (But I can't say, because we don't know if your car has TPI or a carburetor)
Old Oct 12, 2009 | 05:35 PM
Engine: V8 305 5.0
alrighty, thanks. And the P.O. took out the V6 TPI and put in a 350 V8- carb
customblackbird
Aug 15, 2021 10:16 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
mdtoren
Aug 23, 2015 12:52 PM
BurlyChev
Aug 16, 2015 09:08 PM
mdtoren
Aug 16, 2015 05:45 PM
