350 4 bolt main Question
Old Oct 13, 2009 | 09:41 AM
1991firebirdman's Avatar
Hello everyone,
i have an oportunity to buy a chevy 350 pickup motor. i dont know the year because my dad couldnt remember but it has the old school perimiter bolt heads. does any one know if this motor has the 4 bolt mains or is the only way to tell is to take the pan off and look? thanks fo the help
Old Oct 13, 2009 | 09:46 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 4 bolt main Question
there is no casting number that wasonly used on 4-bolt-main blocks. If you want to be sure, you'll have to pull the pan. But you may not need a 4-bolt block. And the 4-bolt blocks tend to have cracks in the main webbing area. If you're okay with under 450 HP and under 6000 rpm, a 2-bolt block is a good choice.
Old Oct 13, 2009 | 10:40 AM
Jimmy D's Avatar
Car: Camaros and Suburbans
Engine: V8's
Originally Posted by 1991firebirdman
Hello everyone,
I'm not an expert in these matters but; there should be casting numbers in two places on the block:
on the passenger side - front and the driver's side - rear.
These will be "machined" surfaces, on the engine block, with some combination of letters and numbers stamped there. Also get the intake (located on the driver's side rear) and pop off a valve cover and get a head casting number, (both are around 8 digits long).
If you have a friend at your local GM parts dealer, (or if you don't - shame on you - make one) - give that person these numbers and ask them to look them up in their "Motors" book manual. The years of use, specifics (4 bolt main etc) and applications for that block will be found there.
Side Note
There are places online where you can look-up your numbers but unintentional deletions and mistakes could have been made when transferring the casting number info found in the original manuals to online websites. This happened to me with my 350 - 4 bolt 1993-94 4WD Suburban; the online info stated that my engine was a 1979 305 2 bolt main. I am the second owner - purchased in 1999 with 40,000 miles on the odometer, (now at 263,000 btw).
Old Oct 13, 2009 | 10:56 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
those numbers cannot tell you if it's a 4-bolt. Even if it can tell you it came from a 1-ton, there's still no guarantee. Plus popping the pan is easier, faster, cheaper and foolproof.
Old Oct 14, 2009 | 04:25 PM
Thanks for all of your input. I was always under the impression that a 4 bolt main block was the better version. i figured that pulling the pan was the best way to tell. can anyone tell me why the 4 bolt main blocks have cracks in the web area? thanks again
Old Oct 14, 2009 | 10:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Jimmy D
Side Note
Just found this while surfing
"Some of the Engine Suffix codes were used a number of times. For example suffix code "CMJ" was used in 1974 on a 350 and in 1980 on a 305.
You need to look at the block casting date and casting number to narrow it down. Do not just rely on the suffix code to identify the original use of the block because it can be misleading in some cases. You should always look at ALL of the casting identifiers to determine exactly what engine you have."
Old Oct 14, 2009 | 11:03 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
350 dude. if you get the engine, pickup a 1 piece pan seal. no sealant needed. reusable neoprene
Old Oct 14, 2009 | 11:09 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
I actually prefer the 2 piece rear main, you can change it with the engine in the car... No stock roller lifters though.
Old Oct 15, 2009 | 09:18 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There are a few commonly held possibilities, and I hold that it's usually a combination of at least 2. So, in no particular order, they are: because the extra holes weaken the webbing (which is true); because the 4-bolt blocks get rebuilt to higher power levels more often (also true); because the vehicles they came in were more prone to detonation (also true).
Old Oct 15, 2009 | 01:29 PM
ok thanks for the info. ill probibly get the engine it was recently overhauled back to stock so its not been built into a gas drinkin fool yet so i think its pretty safe. thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
