1.94 in 081's
Old Oct 13, 2009 | 09:15 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
1.94 in 081's
would it be wourth my time to put 1.94 intake valves in some 081 heads for my 305 TBI? would they be shrouded by the cylinder walls?
also, what size valves are stock in 081's?
Thanks-
Eric
Old Oct 14, 2009 | 08:35 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 1.94 in 081's
Stock is 1.84" intake, so the 1.94s are an easy upgrade. But if you don't also have the shop do a 75 degree bowl hog after cutting the seats, you won't find much improvement. And if you're doing that, you may as well get aftermarket stainless 1-piece swirl-polished valves with undercut stems, and have the shop put a 30 degree back cut on each of them.
86z89iroc
Oct 5, 2015 01:04 PM
WideOpenVTwin
Mar 14, 2002 07:32 PM
89formula#1
Feb 12, 2002 01:41 PM
gruveb
Feb 6, 2001 07:32 PM
rsilver
Nov 8, 2000 04:17 PM
