89 l98 high idle after diven
Old Oct 15, 2009 | 11:30 AM
andrew951*420's Avatar
my car starts fint ,idle high for bout a minet. then goes down to normale idle 600rpm.. after diven for a few minets it wants to idle rond 1500rpm.. if i put into nuteral and slap the gas once or twice it will mello out and idle 600rpm... its been goin on 4 bout a mounth... if u could help ...
Old Oct 16, 2009 | 07:16 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: 89 l98 high idle after diven
Have you done any work on the throttle body lately? I had a similar issue after replacing my intake/plenum gaskets and injectors, setting the IAC fixed it. Instructions are here:
https://www.thirdgen.org/tpimod2
Also, have you checked to make sure the throttle linkage isn't sticking open a little?
Old Oct 16, 2009 | 10:01 AM
ya i did take the intake off to clean and ever sence its been given me trubles.. im ganna go adjust that hopefull i have ur luck with it.. thanx
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Sep 4, 2015 07:57 AM
Hello, Michael
Aug 20, 2015 03:19 PM
