where does this vacuum line go? (pics)
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
the one thats coming from the underside of the engine
My car is a carb'd 1986 Pontiac Trans am 305.
Axle/Gears: Stock
Re: where does this vacuum line go? (pics)
If u have a pic of where it goes that'd help too.. IM not very savvy when it comes to engines =]
Car: 87 T-Top GTA
Take another pic, but NOT as close this time!!! But close enough to see how long the line is and where its going to!
Car: 87 T-Top GTA
by the way, your EGR valve is unpluged...lol (but you probably knew that)
Car: 87 T-Top GTA
I'm really sorry but I don't think I can be of much help. You got Carb, I have TPI. I've tried looking over and over again, and I don't see any vac lines like that on my car.
Sorry Buddy!
Sorry Buddy!
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Did you or when you bought the car do you know if it was tpi to carb swap or just carb all the time? Because the emission isn't anything you need. Unless your in an emission state. But that line does it have air coming out of it or you have any hissing anywhere on the vehicle? Try your heater and if your not blowing hard air out of the vents i think that might your vacuum line for your heater vacuum line. Possible but i still need a more direct picture where it is at couldn't really see it on the pic if you could circle which one it is i might have more an idea. thanks.
Car: 87 T-Top GTA
He may not be in a emission testing state, but the emission canister does have its uses.... You can't just unplug it.... those lines are also coming from the gas tank. Some of those lines are venting fumes from the tank and into the canister.
mdtoren
Aug 16, 2015 05:45 PM
