Car completely dead....HELP!
Old Oct 22, 2009 | 10:36 AM
1BadThirdgen's Avatar
Car: Trans Am
I was driving to work today and I stalled at a stop light, after I did this, I attempted to re-start the car, however everything was completely dead.
No radio, lights, sounds, car doesn't even attemp to turn over. It's like it's dead to the world.
I literally pushed it into the parking lot of work this morning, I have no idea what could have caused this....drove fine till this disaster.....
Thanks in advance
Old Oct 22, 2009 | 11:31 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Car completely dead....HELP!
Sounds like a battery issue. I'd check the battery terminal connections, and battery cables.
Old Oct 22, 2009 | 12:48 PM
Car: Trans Am
That's what I'm thinking....I just tried to jumpstart the car and it didn't even respond or work at all....
I might just replace the battery and connections all at once.
Do they sell the cables and connections at Auto-Zone or do I need to special order?
Old Oct 22, 2009 | 01:05 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
yes, they sell replacement cables at autozone, which will already have the needed connectors. You just have to find the right length ones. They can probably look it up on their computers, but you could also remove and measure your stock ones.
Old Oct 22, 2009 | 01:18 PM
Car: Trans Am
Alright, I'll give them a call when I get out of work....I'm gonna go and try to mess around with the cables and see what happens....
thanks for the help.
Is it possible that anything could have caused this?
Old Oct 22, 2009 | 01:27 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
that happened to me before. it was just a bad ground from the battery terminal. just needed tightened
Old Oct 22, 2009 | 01:28 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
I would suspect corrosion at the battery terminals. I pull mine loose a couple times a year and clean them.
Old Oct 22, 2009 | 02:28 PM
Car: Trans Am
I'll check on this as well, it's only connected in one spot near the battery? Or is there another I should check?
Old Oct 22, 2009 | 02:44 PM
Engine: 383 hsr
well since i had to relocate my battery, i took my negative batt cable and grounded it to the a/c bracket. so i would have to look at my car to see where it was originally grounded. but you can ground it anywhere you like.
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
