Correct gasket kit?
Old Oct 23, 2009 | 02:34 PM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Correct gasket kit?
Need a full gasket set for my carb'd vortec 350 build. It is a late 90's block with one piece rear main seal.
nvm that was the wrong set. someone please link me to the full engine gasket set i need.
Old Oct 23, 2009 | 03:06 PM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
Re: Correct gasket kit?
""""carb'd vortec 350 build.""
you have apples AND oranges both.
You might have to buy the intake set separately if you have vortec canted intake heads and an aftermarket Al manifold. If the case is an LT series thats different. Do some homework as to the parts you are using.
"""""It is a late 90's block """"
later than 1993????????
"""" with one piece rear main seal.""""
all that means is it's 1987 and later.
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
g.l.mos
Aug 22, 2015 12:02 AM
