help chosing a plug tempeture
Old Oct 25, 2009 | 09:02 PM
Hiemarch's Avatar
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
So I'm finally yanking the old 305 TBI and installing my 377(stroked std bore 350) with supper ram intake, +5cc Keith blacks 64cc aluminium heads. I'm looking at about 450hp at the crank I hope and trying to figure out what plugs to use on the engine, definitely going with platinums however I doubt that the stock temperature plug will not do, any advice on where to start?
Old Oct 25, 2009 | 09:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: help chosing a plug tempeture
Stock plug heat range will probably be fine. I see nothing needing a colder temperature plug.
A plug needs to be hot enough to burn off the deposits but not so hot as to melt the electrode. Run the coolest plugs possible that don't foul.
Platinum plugs are only needed when they're difficult to access or you're too lazy to change them regularly. A regular copper plug will work just fine, are a lot cheaper plus they're easier to read.
When reading the temperature range, look for the bluing on the ground strap about 1/2 way down. If the color changes near the tip, the plug is too cold. If the color change is near the base, the plug is too hot. New plugs are the only good way to read temperature.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
