TPI car falling on it's face
Old Oct 27, 2009 | 10:32 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Alright, i am getting closer to the solution here. I have a 91' TA TPI. Car runs fine when it is first started and driven. Like in the morning. Ok. after about 20 min. it chokes like hell when you accelerate! I have ohmed all injectors, they are fine. Also, no codes. No vacum leaks either. I am suspecting it to still be a bad sensor, or even the pickup coil in the distributor. Is there a way to test pickup coil for resistance? Anyway, the other day i tried the resistor thing on some of the sensors.. I used a resistor in the air temp sensor under the plenum and it ran fine , no codes. (Idea is to use a resistor and temporarily trick the computer to think the intake air is colder than it really is, which will raise timing and richen fuel mixture.) Ok, so it did. Now , at the same time i used a resistor in the knock sensor(to basically bypass it). Ok, that worked too. Timing actually felt a little too high. Did not choke on acceleration anymore though. Well, at this point i grew afraid of what they call silent engine knock and so i reconnected my knock sensor. I did leave the air intake sensor with the resistor in it. Drove the car again. So far so good. Then all of a sudden, i suspect the computer caught on to the change in the air intake temp sensor and then the car started really really choking when i got on it! Worse than ever. Couldn't even pass a vw bug.wtf? Ok, so i put everything back to normal and the car ran great again for a while. WTF could be going on here. Bad knock sensor?
Old Oct 28, 2009 | 11:18 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: TPI car falling on it's face
Check your coolant temp sensor.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
