Need Advice on Choosing Ignition System
Old Oct 29, 2009 | 07:23 PM
sr20fd3st's Avatar
Car: 84 Z28, 68K Miles
Engine: 10.5 Compression 350
Axle/Gears: 3.83
I need a new ignition system for my carbed, non-computer Camaro.
I want a new distributor with an ignition box. I'd like to get a Mallory
Unilite since I've had good luck with them before, but I'm not sure how big they are and if they will clear the cowl on the 350 that's sitting in the engine bay right now (stock distributor only comes out if you remove cap first...lame).
As for the box, all I want is something that will hook up with no hassle to the distributor and coil (will get a separate coil). The Box Definately needs to have start-up ignition retarding. My current starter has so much trouble cranking my engine what I have my idle timing at 15 degrees advance, that the only way to start my car is to back the timing to about 0 degrees, start it up, then turn it back to 15 where it runs right. A box that would retard timing from a signal from the lock cylinder when I go to start the car would be amazing.
Pretty much open to any ideas, proven combos, etc. that meet these requirements.
Thanks,
Oliver
Old Oct 29, 2009 | 07:34 PM
Shadow Z's Avatar
Car: Lots of 'em
Re: Need Advice on Choosing Ignition System
I've had very good luck with the Accel ignition I have, check them out.
http://www.accel-ignition.com/
Old Oct 29, 2009 | 10:22 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
i would suggest MSD. it is a little more exspensive but you will have no problems.
i had accel a while back. my buddy told me not to get accel bcuz he had problems. however i could afford the msd at the time. so i got accel. and let me tell you. i was replacing their coils quit a bit. at fifty bucks a pop each time. for some reason the coils didnt last long, i checked everything which was all fine.
so eventually i saved up and got msd. havent had one single problem.
hope my story helped you... ha
Old Oct 29, 2009 | 11:21 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Check out Summit's house brand combo kit, it's a Mallory box and will will work great for you..at the best price I've seen.
Old Oct 30, 2009 | 12:11 AM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Davis Unified all the way!
http://www.performancedistributors.com/
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
solocus
Sep 2, 2015 12:14 PM
WIzmo
Aug 30, 2015 02:30 PM
Thaney9
Aug 29, 2015 03:16 PM
