Engine Sounds like a miss???
Old Nov 2, 2009 | 03:05 PM
891-92camaro's Avatar
Car: 92 camaro 25th anniversery
Engine: 350 TBI
Transmission: 700 R4
Axle/Gears: 3.73 9 bolt
I have a 92 camaro RS with an 89 350 in it it has a custom computer chip, exhaust, intake and TBI work done. about a week ago it started to sound like it was missing it idels rough and shutters and hesitates under acceleration. Since then i have put a new TPS sensor Map sensor fuel filter, and cap and rotor, when i removed the cap and rotor i noticed that the node that fires number 6 was corroded and looked different then the rest so i thought the new cap and rotor would of solved the problem, I ran it for a couple days and it still sounded like it was missing and now the new cap looks the same way on the number 6 node as the old one did. I have tested the pickup coil in the distributor and the remote coil too and both tested ok. I have also been getting an EGR code but it is opening and closing fine so i think something else is triggering the code. I have no idea what else it could be I am stummped any suggestions?
Old Nov 2, 2009 | 03:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Engine Sounds like a miss???
change plugs n wires, they don't last forever like the newer cars.
And these cars eat ign parts like candy.
Also keep track of said plugs when taken out, which is which.
post pics
Old Nov 2, 2009 | 04:58 PM
Engine: 350 TBI
The wires and plugs are new.I put them in when I put the engine in about 6 months ago the wire on 6is good I checked it with an electric meter. But I am going to replace the plugs.
Old Nov 2, 2009 | 05:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
6 months doesn't mean anything; check each wire with an ohm meter for proper resistance. change plugs.
Run car in the dark with hood open, look for spark leak, then mist with a water bottle, should still see no fireworks.
If ya see any spark.....
The spark will take the path of least resistance, even if that mean coming through the rubber shield, or out the side of a coil.
Old Nov 2, 2009 | 06:10 PM
Engine: 350 TBI
Ok I will give it a try thanks.
Old Nov 4, 2009 | 03:30 PM
whitelightnin92's Avatar
yeah his car shocked the $HIT outta me earlier when i touched a plug wire! not supposed to happen!
Old Nov 7, 2009 | 05:29 PM
Engine: 350 TBI
Well i told you not to do it lol
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
