leaking coolant near rear intake manifold
Old Nov 3, 2009 | 05:56 PM
Stigmata's Avatar
87' pontiac firebird t.a. 305 FI
i have a problem and i can't seem to get it fixed.
awhile ago my i replaced the intake manifold gaskets, there seemed to be a coolant leak around it so i replaced it and the problem went away. a couple of months later i started to smell burnning coolant, i inspected it once again and found a leak on the rear right/passenger side of the engine where the remote ingnition coil harness was bolted down with the manifold bolts. i took it apart and looked inside only to find that the whole engine was full of mixed coolant and oil. the gaskets a ruined and so i have to replace them again, but before i do i'd like some helpful advice from some who has experience. please help me!
Old Nov 3, 2009 | 05:58 PM
Twin_Turbo's Avatar
Re: leaking coolant near rear intake manifold
Did you apply RTV around the coolant ports? Both sides of the gasket and run the bead into the rear china wall. That'll seal it up.
Old Nov 3, 2009 | 06:02 PM
Stigmata's Avatar
me and my buddie did that though, it still leaks, and when it leaks it sprays out from the bolt and below between the intake and block.
Old Nov 3, 2009 | 06:19 PM
Twin_Turbo's Avatar
The bolt is not connected to the coolant port either the head or the manifold is cracked.
Old Nov 3, 2009 | 07:30 PM
Stigmata's Avatar
aw dam i hope it's not it, it the only car my parents gave me hahaha
Old Nov 4, 2009 | 01:41 AM
Stigmata's Avatar
hah i just found out that my bolts are tty bolts
Old Nov 4, 2009 | 02:06 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
How long did ya let the RTV dry?
Had lots of pro's even GM engineer say to only use RTV for the china walls on the ends.
For the rest of it use ThreeBond 1194 as once RTV is set, thats it.
3B is a semi drying liquid gasket and seals better in the long haul.
YamahaBond use to be good also till they changed it.
Jake_92RS
Jan 28, 2020 10:37 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
