Bolt snapped
Old Nov 4, 2009 | 03:52 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Bolt snapped
The bolt for my starter broke off about a 1/4 inch into the block at the threrads.. how do i remove the bolt piece stuck up inside?
Old Nov 4, 2009 | 06:26 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Bolt snapped
If there is nothing to grab, I would drill it out and retap it. Center punch it first and make sure you drill straight. You can try an EZ out, but don't put much pressure on it. If you snap that off in there, you're really in trouble.
Old Nov 4, 2009 | 06:58 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Re: Bolt snapped
Try an EZ out. The work most of the time. Especially if it is not a hardened bolt.
Old Nov 4, 2009 | 10:13 PM
toomany's Avatar
Re: Bolt snapped
When drilling the hole for the EZ out, use a left handed drill bit. Sometimes you'll get lucky and that will spin it out. Is this the bolt on the edge of the block? If so, watch out. I've seen a few blocks crack right there.
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
