402 BBC overbore
Old Nov 8, 2009 | 02:26 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
402 BBC overbore
I once heard thats a 402 BBC could be bored out to 4.25, making it a 427, is that possible without hitting water, and still having plenty of cylinder wall left?
Old Nov 10, 2009 | 04:49 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Re: 402 BBC overbore
Im no expert but if you have a 400~ block I believe the recommended max is 406-412 with boring, as you WILL "hit water" lol
I think to hit 427 you need a large than 3.75 crank.
On the other hand, they SELL 400CID blocks that you can bore/stroke to 450~ cubic inches. But thats not a run of the mill 400, its a special order only block from a summit magazine.
Old Nov 10, 2009 | 05:09 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
oops
Old Nov 10, 2009 | 05:48 PM
toomany's Avatar
You're talking SBC's, OP is talking BBC.
402's have a bore of 4.125" with a 3.76" stroke. According to my book (Chevy Rat Motors by Ed Staffel), if there is no core shift they can be bored over to 4.250". Making a 427 (with the 3.76 crank) or a 454 (with a 4" crank).
Old Nov 10, 2009 | 06:22 PM
ericjon262's Avatar
thank you. thats what I needed to know!
Old Nov 10, 2009 | 06:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An opinion from the other side:
Some 396's, with 4.096" bore, used the same casting as the 427, which was 4.250" bore. So, those blocks can be taken out to 4.250". But, from what I've been told, the 402's, even with a larger 4.125" bore than the 396's, had thinner cylinder walls, and a 0.060" overbore is all you should take them.
Best bet would be to have the cylinder walls measured.
Old Nov 10, 2009 | 10:33 PM
ericjon262's Avatar
I planned to, I've been researching this as best as I can, and it seems very hit or miss, some have done it without incident, others have said you can't, what would be an acceptable wall thickness for a 402?
Thanks-
Eric
Old Nov 11, 2009 | 03:07 PM
five7kid's Avatar
Quick search:
http://books.google.com/books?id=_i_...age&q=&f=false Says 0.125" at 1" below top of cylinder.
Old Nov 11, 2009 | 08:41 PM
ericjon262's Avatar
Thanks five7, thats what I needed to know.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
vortec tpi
Sep 26, 2015 08:14 AM
vortec tpi
Pacific Northwest Region
Sep 26, 2015 08:13 AM
