Labor Time from shop manual /chilton's Manual to change fuel pump
Old Nov 9, 2009 | 11:47 AM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I need to know the labor time listed in a shop manual like Chilton's etc... to change a fuel pump out of a 1991 Camaro ( complete time from start to finish)
Old Nov 9, 2009 | 02:03 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
Re: Labor Time from shop manual /chilton's Manual to change fuel pump
Im pretty sure chiltons doesnt list labor times, the only place Ive ever seen them is in special books that auto shops have. Ive tried to find them online but the only access is a subscription type thing like all data.
Unless someone with the actual auto shop book chimes in, your best bet is to probably just call a shop.
Old Nov 9, 2009 | 04:21 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Parts lists have the book times.
3.8 hours not including draining of fuel.
Old Nov 9, 2009 | 04:45 PM
Zwrench's Avatar
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
Back when I was still working in a dealership, we had two labor rate books to go by. Chilton and warranty. If it was customer pay, you went by Chilton times and if it was under GM warranty you used the warranty book.
Incidentally, warranty time was 1.8 hours. Even using a hoist and air tools, it was tough to make that job pay.
Old Nov 9, 2009 | 04:49 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I can imagine. I've done 2 pumps. 1 took 7 hours and the second took 3.
Old Nov 10, 2009 | 07:46 PM
THETANK's Avatar
Car: 91 rs
Ok thanks
Old Nov 10, 2009 | 07:53 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
im on alldata right now and it sais 3.8 hours, without draining tank. just like viprklr said.
Old Nov 10, 2009 | 08:00 PM
Engine: 383 hsr
and out of curiousity, i checked out other years of the 3rdgens and the 82 camaro (non carbed) only booked 3.0 hours. hmm lol. and for the carbed ones, it was only 1.0 hours of course.
but it was only for 82 that the time was a half hour shorter with the electric in-tank pump like all the other years up to 92 had....
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
