Speedometer wrong
Old Nov 14, 2009 | 09:29 PM
suks2bu37's Avatar
Car: 1983 Pontiac Trans Am Daytona Pace
Engine: 305 Crossfire injected
Transmission: 700R4 with shift kit
Speedometer wrong
Got the new speedometer cable installed today. Now here is the problem. it shows I am going 35mph when I am only going 25. I know the rearend gears are 3.73, not the factory 3.23. This is in a 83 T/A. Do I need a different transmission drive gear to get it into proper range and where do I get one?
suks2bu37
Old Nov 15, 2009 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer wrong
Welcome to TGO. Listing your car, make, model, motor and trans is always helpful. For example, you don't mention if you have the 700R4 (auto) or the T-5 (manual).
Yes, you'll need to change the driven gear. Check the stickies in the Transmission and Drive Train section for the proper gear.
You'll be able to purchase what you need from the following company:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Nov 15, 2009 | 09:37 AM
suks2bu37's Avatar
Sorry,
The car is a 1983 T/A Daytona 500, the transmission is a 700R4. Motor is the crossfire injected 305. I will check the stickies and see what they have to say for me being an idiot.
suks2bu37
Old Nov 16, 2009 | 01:43 PM
Guest
Guest
Posts: n/a
You need the 15 tooth drive gear. Driven gear depends on your tire size.
Old Nov 16, 2009 | 03:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Drive gears, you must remove the tail shaft housing, which means pulling the drive shaft, and some fluid might leak out.
Driven gears can be changed with out pulling the tail shaft housing, unless it stuck in there good like it is most times and ya end up pulling the tail shaft housing to knock out it anyways
Car angle will depend on the amount of fluid leakage.
Jack up all 4, for less loss/mess.
Its fun, never got mine 100% cause of my odd combo.
But I’m cool with it being 5 under. At 60 its 55.9, so natural instinct to run 5 or more over, keeps me in the safer zone when putting around town.
Old Nov 16, 2009 | 03:53 PM
Guest
Guest
Posts: n/a
that's true, but the speedometer WILL NOT calibrate with a 17-tooth drive and 3.73:1 gears. Let alone 18 tooth or 19 tooth.
$750 L98
Feb 1, 2025 02:25 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
