rare starting problem, Help please
Old Nov 19, 2009 | 08:06 PM
Liquidsteel's Avatar
I have a 1991 trans Am with a 383 tpi. MSD ignition
The problem is the car will start and run for a while. Once the engine heats up a little it shuts down and will not start again. But if i unhook the battery and come back a hour or so later. It will fire up right on the dime, but have the same symptom.
The distributor is new, plenty of spark, Fuel pump is coming on.
Old Nov 22, 2009 | 11:08 AM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
Re: rare starting problem, Help please
is it the right battery for the car?
Old Nov 22, 2009 | 12:13 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Had the same problem with mine, unhook the msd, put it back to stock
and try it again
Old Nov 22, 2009 | 07:07 PM
Figured it out. THe CTS was bad, and the tps was bad OHM it out, was Flooding the cylinders out, thanks you for all the help
jaridjohn
Jul 8, 2024 03:49 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
