Running fine but smell fuel after driving.
Old Nov 23, 2009 | 07:00 PM
shingadaddy's Avatar
Car: 91 Z.
Engine: 5.7 TPI
That pretty much sums it up. No starting, Idling or running issues. I have the FUEL INJECTOR CONNECTION Bosch Gen III injectors from John. Fuel pump replaced 2 years ago.. I cant find any liquid fuel anywhere up front and cant tell if its coming from front or back.??? Just seems all around the car when you get out.
I haven't noticed any pressure in the tank when removing the cap lately but its cold now. Charcoal canister not smelling of gas.
The tank should hold pressure blowing into it by mouth shouldn't it?
Going to try this now but any other suggestions appreciated.
Old Nov 23, 2009 | 10:04 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Running fine but smell fuel after driving.
I don't suppose you cut your fuel lines and spliced them with hose when you changed the pump?
Old Nov 24, 2009 | 07:46 AM
Car: 91 Z.
Engine: 5.7 TPI
Tools and time. Dropped the rear and did it by the book. Not my only driver luckily.
And I mis-spoke. There IS a good deal of fumes coming from the charcoal canister. You just have to run it for a while to get it to do it.
There is an open port at the top of it with a small white tip on it .
I dont see a line that would go to it. Looks like it should have one. Is there supposed to be one on it?
Old Nov 24, 2009 | 09:23 AM
jv9999's Avatar
Engine: 5.7L/350
Smart man. There should be a vacuum line going to the purge solenoid. The canister stores the fumes in the charcoal until the purge solenoid opens and sucks them into the the intake.
Old Nov 24, 2009 | 09:42 AM
Car: 91 Z.
Engine: 5.7 TPI
The canister has a Larger line going to it but on the top of the diaphram there is this other port looking hookup that I described. I'm guessing it should have a SMALLER vac line on it?
Now where the heck does the other end come from??
Old Nov 24, 2009 | 11:08 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Is the vacuum hose routing diagram still under the hood somewhere?
Old Nov 24, 2009 | 11:44 AM
Car: 91 Z.
Engine: 5.7 TPI
Should be. I'll look after work. I have the shop service manual too. Can't figure where the line might be. I looked around a bit for one but I was hurried, like usual..
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
