bad things happen
Old Nov 29, 2009 | 11:03 AM
perpetualjoshie's Avatar
Car: 86' Z28
Engine: 5.0l w/ new cam
Transmission: TH-350
Axle/Gears: 4.10's
bad things happen
It is time once agian that i call upon the collective knowlage of tgo. a few days ago i was driving home from school and my camaro started running very rough. its stumbling off the line and under acceleration to the point where its undrivable. idle is somewhat irratic going anywhere from 1200-1600rpms. its also running very rich, the exhaust smells very strongly of gas. this happend all at once, took off from a stop sighn and bam. ive checked a few things so far, fuel pressure 42 psi with vacuum 48 psi without vacuum. all injectors OHMs are between 16-18. vacuum itself is at 17 hg, same as it was a few months ago. going to check TPS and IAC later today along with plugs and wires. any ideas/help would be greatly appreciated.
Old Nov 29, 2009 | 11:57 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: bad things happen
tps.. onetime leaving fro m school id get missing upon throttle. the tps was at .79 volts at idle!! set to .54v. saved the cat.
Old Nov 29, 2009 | 05:58 PM
Car: 86' Z28
Axle/Gears: 4.10's
TPS and IAC are good. wires look good, plugs are starting to get black from running to rich, but are still mostly tan. they all reak of gasoline. could this be a O2 sensor problem or a bad CTS?
Old Nov 29, 2009 | 06:17 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
sounds like maf sensor to me, unplug your maf and note the change.
did you check your fuel pressure with the engine under a load (pumps only sometime fail 100% all at once). In otherwords you may be experiencing a lean condition under load.
Old Nov 29, 2009 | 06:31 PM
yeah check the CTS, replace it and the wire connector. defiantly that. to test the maf, check for codes first, first while the engine running, carefully slap the maf. fearful of the alternator and fans. i dont think the o2 sensor would do that
Old Nov 30, 2009 | 09:44 AM
Car: 86' Z28
Axle/Gears: 4.10's
Ill replace the CTS later today and see it it makes a change. the computers not throwing any codes. if by under load you mean with the engine on, im at 42 PSI from the pump. ill try unplugging the maf and see what happens. thank you for the responses.
Old Nov 30, 2009 | 10:10 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Got a scanner? See what temp the computer thinks the engine is before just replacing a possibly good sensor.
Old Nov 30, 2009 | 10:22 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
by under load he means reving the engine to above an idle. Say 3-4k rpms.
Old Nov 30, 2009 | 06:18 PM
Car: 86' Z28
Axle/Gears: 4.10's
oddly enough, the problem has gone away. all i did was fill up the tank and run injector cleaner through it. while driving today the stumbling and smell got bettter and better until it was gone. im thinking that i may have sucked up some gunk from the bottom of my tank (problem started when i was very low on fuel.) and it clogged up on of my injectors. thanks again for everyones imput
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bob88GTA
Aug 18, 2015 03:31 PM
BurlyChev
Aug 16, 2015 09:08 PM
mustangman65_79
Aug 8, 2015 12:07 PM
