Plugging the oil cooler adapter
Car: ‘08 Grand Prix GXP
Engine: LS4
Transmission: 6 banger auto
Axle/Gears: 2.93
My brother has a 350 out of a '95 Tahoe in his '88 formula. It still has the oil cooler adapter installed. Well we went to go replace the oil cooler lines and they are rusted stuck in the adapter. After removing the adapter we were able to remove the big "nut" type things that screw on to the adapter that the cooler lines go into. There is no way we can get the lines out without killing the "nuts".
So my question is, if anyone has done this, now that i have the "nuts" off i can screw a cap of some sort on the adapter and block off the 2 cooler line holes. Can i do this? Or is the cooler adapter designed to have the oil go through no matter what. I'm not looking to blow up the motor. But we're kinda in a pinch. TIA.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Plugging the oil cooler adapter
There is probably a thermostatically controlled bypass, (doesn't go thru the cooler if the oil is below X temp) but i am going to guess that just plugging the holes is going to be a bad plan. Just get the right parts so that you don't need the thing. Should be available at the parts store, and even pretty cheap at that.
Car: 87 GTA
The coolant lines only pass.....coolant.
My stock one on my GTA, got the hard metal coolant lines busted by a balancer that came art. I simply took them off & left the adapter wide open. No problems since.
Engine: 5.7 TPI
I know the stock coolers on the F-Bodies just ran coolant thru a sandwich adapter, however, on some of the trucks, oil was actually passed thru a cooler in the radiator, similar to the transmission cooler.... knowing which type it was on the original vehicle would be important here.
Car: 87 GTA
I doubt the engine pumps the oil out to be cooled.
If not, why not just leave it off & put you oil filter directly on the block? Might need to transfer the center threaded section from the cooler piece to the block, but as long as there is room for a filter, that should be all there is to it.
Engine: LS4
Axle/Gears: 2.93
The Tahoe 350 sends oil from the adapter to the radiator. And back to the motor
Do you have room to ditch the cooler/adapter competely, install a regular filter-only adapter into the block and screw on a filter that points in the traditional "straight down" orientation? Even if you can't fit a long-style filter.
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I ran my old 305 w/ cooler lines off no problem. I had the same sit. when my balancer grenaded into pieces
toronto formula
Nov 10, 2015 06:17 AM
BurlyChev
Aug 22, 2015 01:52 PM
Navy8125
Aug 21, 2015 09:32 AM
