Noise Eminating From Distributor Ideas??
Old Dec 10, 2009 | 08:13 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I was looking at an 89 Formula 305 TBI L03 tonight tht I am thinking about purchasing. When I checked under hood there was a mild grinding (although that description is not quite correct) a noise almost like the sound of a bearing going bad, you could hear the tone change when you grabbed the cap. After I drove the car which had good power (considering its an L03) and no apparant miss in the timing, the sound was gone. Any Ideas. I did not pull up on the distributor to check to see if it was loose I will call the guy and tell him to check that. Outside of that any ideas??
Old Dec 10, 2009 | 10:24 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Re: Noise Eminating From Distributor Ideas??
Of course first check to make the distributor bolt and cap are tight.
It could be the distributor gear going bad. Distributors do wear out and are not too expensive to replace. Others will know more than me but I think it is a good starting point.
theshackle
Sep 17, 2020 08:26 AM
pimp2303
Jul 27, 2017 02:03 PM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
