305ci Combo's - what have you got?
Old Dec 11, 2009 | 08:14 AM
Quinny's Avatar
I am curious to see what people are doing to their 305s - specifically carby LG4 (up to 86) engines. I have read the 305 Performance threads, but I am interested to see what people on here are running and what the results are. Trying to get a feel for what works on these engines, as carby Chevs are still a bit alien to me.
So, what pistons, heads, cam, intake, stall converter, diff gears etc do you run? What sort of power and/or strip times do you get from your combo?
Old Dec 12, 2009 | 08:56 AM
ckeene502's Avatar
Re: 305ci Combo's - what have you got?
years back i built one with vette alum. heads, tpis cam, rpm intake, bg carb. ran great and fun to play with. had a t5 behind it and 3.42 gears. i still have the heads and cam. looking for a 350 now.
Old Dec 12, 2009 | 06:08 PM
Firehawk1990's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 3.27 Limited Slip/Positraction
i have a almost stock 305tpi throttle body of a LT1 350 accel ignition ferro spiral plug wires and bosch platnium plugs no ac,ps,ap
Old Dec 24, 2009 | 08:21 AM
ocsurfer999's Avatar
Car: 1992 Pontiac Trans Am GTA
Engine: 5.7
Had an 84' TA with 305 HO. Knew it had a couple of burnt valves on #1 & 3 then blew head gasket on right side. Figured since the engine had to come apart I should build it right. Orange Engine Builders went .060 with a 400 crank, new comp cams springs & lifters, manley valves, and new cam. Had a custom cam machined from Mr. Horsepower, Clay Smith Engineering. Dynoed at 325 rear wheel power and 362 ft lbs torque. Clay Smith was able to design a great cam that gave great power and I still was able to pass CA Smog Test.
Old Dec 24, 2009 | 08:39 AM
Engine: 5.7
I let them pull the engine and do all of the machine work to the block and heads. Had stock 700R4 and stock 3.23 gear. Total cost was $2800 but my friend's father worked there. Never raced it because it was my daily driver and I did not want to risk tearing it up. Some punk with a 5.0 rustang, was drunk and clipped me on the 405. The car spun and i was t-boned by a semi. I walked but my car was a totaled. Stripped everything and sent bones to Pick - A - Part.
Old Dec 24, 2009 | 08:03 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
my combos in the sig. its a daily driven car 26 miles to work one way, 3k rpm+ on the freeway, usually at 65-80 and its a blast. still working out the bugs so no numbers.
Old Dec 29, 2009 | 07:01 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Here's the cheap option:
'86 LG4 - bone stock engine EXCEPT for the 90-shot, 3.73/Torsen:
13.1 sec @ 102 mph with stock TC, hoping for 12.9's with the S10 TC in it now. 25 mpg hwy.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
scotrans am
Sep 5, 2015 04:26 AM
