This a good rebuild kit?
Old Dec 25, 2009 | 09:59 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
http://www.northernautoparts.com/Pro...tModelId=18785
Am gonna get the machine work done on the block i decided. This a good kit for my L31 motor?
Any clue on area of HP to the crank with this setup and a good 750 carb?
Goals were 400hp to crank and 100 shot down the road.
Old Dec 25, 2009 | 10:22 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: This a good rebuild kit?
that kit doesnt show a crank and that cam is tiny for a 383, I was going to run a bigger cam in my 305 tpi fwiw
Old Dec 26, 2009 | 05:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
AND make sure you have your machinist balance the rotating assembly even if the kit claims "balanced".
Old Dec 26, 2009 | 08:08 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
yes am gonna have them do all things neccessary. If theres a better kit out there that can net me arond 400hp and withstand a 100 shot please let me know. thanks for the responses
Old Dec 28, 2009 | 07:48 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
ok i got a price for getting the block dipped, honed, balanced and prepped for the 383 Kit.
$675, new frost plugs, cam bearing, line boring....
Is that a decent estimate or should i start looking elsewhere. This is with me breaking the block down, they wanted $150 for taking it apart plus 1.5 hrs at $110/hr to get the block done.
I was doing some research and seen i could get a 383 forged short block for around $2200. In the long run should i get the new short block and use the L31 as a donor or just use a shop to clean up the L31?
Old Dec 28, 2009 | 11:22 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Ive read numerous times line honing the mains is a very expensive waste of time. David Vizard specifically says not to do it in one of his books.
Old Dec 29, 2009 | 09:37 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I went with eagle kit the one I got lists good for 500hp and got it for 750 ebay. Several diff suppliers for same price. Also have read that line bore is waste of money unless your going for 800hp and up.
Old Dec 29, 2009 | 09:58 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i have used their rebuild kits several times . never had a problem . just my thoughts & experince . good luck .
Old Dec 30, 2009 | 06:47 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Thx for the reply and thoughts guys.
2 more questions.
Next year (2011) am most likely gonna change the vortec heads to something different. But as of this year am just gonna use the stock vortec heads with alittle work. Is the LT4 hot cam my best choice in cams for those heads?
Also what size headers you reccommend? Am gonna run a trual dual exhaust with 2 1/4 piping side by side to the rear. Or maybe 3 1/2 single. Not sure what would be the best route,i dont want to change the exhaust if i decide to go with a bigger and aggressive cam with heads down the road.
Just remember this is not a fuel economy car, i could care less if i get 4 mpg :P this is my pre life mid crisis car as am not old enough yet for a mid life crisis as the wife told me lol
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
hectre13
Aug 26, 2015 08:17 AM
TreDeClaw
Aug 14, 2015 06:58 PM
