belt routing diagram for V-Belt equipped firebird
Old Dec 13, 2009 | 01:39 PM
sflthndrckn's Avatar
Hey guys im going to be removing the smog pump from my 83 LG4 equipped firebird and have scoured the internet all day to try to find a routing diagram that isnt the serpentine pattern. could anyone please post up such a diagram?
also does anyone have a write up of what all hoses and lines are part of the smog system? underneath the hood of my car it looks like a spiderweb of vaccum hoses and i dont want to remove or plug up something vital.
thank you in advance.
Old Dec 13, 2009 | 01:49 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: belt routing diagram for V-Belt equipped firebird
It might help top post the model year of your car. IIRC, there were differences between model years.
Old Dec 13, 2009 | 01:54 PM
Originally Posted by sflthndrckn
Hey guys im going to be removing the smog pump from my '83 LG4 equipped firebird and have scoured the internet all day to try to find a routing diagram that isnt the serpentine pattern. could anyone please post up such a diagram?
Old Dec 13, 2009 | 02:16 PM
Stephen's Avatar
Car: 87 GTA
Why are you taking it off? Is this a street car?
Autozone.com might have it. The decal showing it is gone from my car, so I can't take a pic & post it for ya.
Old Dec 13, 2009 | 02:30 PM
Guest
Guest
Posts: n/a
The smog pump on an 83 is driven by its own belt off the water pump, and its right in the front so taking it off is simple.
Old Dec 13, 2009 | 03:01 PM
its a street car but its also a florida car lol. just to be certain when facing the engine compartment the smog pump is the bottom left (passenger side) pump. is that correct?
Old Dec 13, 2009 | 03:12 PM
Stephen's Avatar
Car: 87 GTA
Correct. But why do you want to remove it? You may be in Florida, but....
it is a FEDERAL requirement to have, regardless of state inspections.....
it costs you less than 1 horsepower.....
requires a lot more than simply unbolting it & your done.
There is the AIR tubes on the exhaust, the tube to the cat, the valve/box thingy (dunno what its called).....that is all connected to the smog pump in one way or another.
Old Dec 13, 2009 | 03:28 PM
I'd like to remove it to clear up space and weight in the engine bay as well as the few horsepower that doing so will net.
i also have a set of hooker super comps that will be going into the car soon which will be made easier without the maze of pointless pipes spanning every bit of free space for the purpose of "injecting clean air into my exhaust".
Old Dec 13, 2009 | 04:14 PM
Stephen's Avatar
Car: 87 GTA
This has been discussed before....
Dyno it before & after. You won't get any more HP than you would get in the variation between 2 back to back runs.
You'll hafta pull a lot more than just the pump anyways, then plug things shut.
Old May 15, 2019 | 02:10 PM
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
The top photo should be the closest to your engine I could find
1992 Trans Am
May 10, 2023 07:19 PM
Glowsock
Jan 9, 2017 04:06 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
scottmoyer
Interior Parts Wanted
Aug 9, 2015 10:18 PM
