305 Vortec heads
Old Dec 14, 2009 | 06:10 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
305 Vortec heads
i found a set of 96 305 vortec heads for cheap, and im currently running a 89 305 with the stock heads, but i want to get some add ons as i build up my 350, so im doing everything that is swapable to the 350 from the 305 first (gotta have some fun) but alot of people are saying stay away from the 305 vortecs, and others say go for it. Im going to pick them up but whats peoples 2 cents are on them.
planning on
305 vortec heads, roller rockers, beehive springs, mild port, valves
350 roller with lt4 cam
4 barrel carb with rpm air gap
ps the 350 is not going in till i can afford an aftermarket trans my t-5 wont hold up. ps.ps any where that i can get that upgraded to stand to a 350?
Old Dec 14, 2009 | 09:00 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
Re: 305 Vortec heads
I have no experiance with the 305 vortecs.I can however tell you that with their 58cc chambers,a 350 will require one hell of a dish to arrive at a realistic compression ratio.Just something to keep in mind,the few dollars you save on the heads now,could end up costing you way more if you have to get a set of oddball pistons later.
Old Dec 15, 2009 | 01:39 AM
Quinny's Avatar
Eagle do kits with -12cc Keith Black pistons. With a 58cc head, zero deck and .039" (8cc) gasket, yields around 10.2:1 comp, so you shouldn't need custom pistons.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
