rear end 9-bolt
Old Dec 15, 2009 | 06:15 PM
tealcamaromanrs's Avatar
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
rear end 9-bolt
i think i am going to purchase a nine bolt posi rear end with disk.but i am not too sure about a couple things.
nine bolt means thats the number of bolts in the diff. cover???
is a nine bolt good or bad???
i have a 91 camaro vert w/ 350 tpi w/ maybe 300hp is 9 bolt big enough??
what do i need to change from my drum to the disk bbrake setup??
any info would be greatly appreiciated...thanks
Old Dec 15, 2009 | 06:22 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end 9-bolt
Yes.
A bit stronger than a 10-bolt.
Yes.
Proportioning valve and e-brake cables.
JamesC
Old Dec 15, 2009 | 06:28 PM
Engine: 383 tpi
Transmission: t5
Re: rear end 9-bolt
ok so just to get this right a nine bolt is stonger than a 10 bolt??
and the propotioning valve i can purchase at ...auto zone or advanced>>?
Old Dec 15, 2009 | 06:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: rear end 9-bolt
Yes but not by very much. Your 91 10 bolt is almost as strong since the 10 bolts started using 28 spline axles in 1990. Your 10 bolt has a 7.625" ring gear. The 9 bolt has a 7.750" ring gear. Both are equally small.
The extra strength of the 9 bolt is from a slightly larger ring gear and a 4 spider carrier. It also has bolt in axles similar to a Ford 9", Dana 44 etc. If it has a posi and the posi is worn out, it's expensive to replace it because it's not designed to be rebuilt. There is little to no aftermarket components for the 9 bolt unless you get them from Australia.
You would be better off just doing a disk brake swap onto your 10 bolt.
Old Dec 15, 2009 | 06:51 PM
Quinny's Avatar
Re: rear end 9-bolt
9-bolt parts from Australia? Why is that? I am in Australia looking for a Camaro (which are pretty rare here), and figured that diff parts would be impossible to find...
JamesC's Avatar
Re: rear end 9-bolt
A bit stronger, yes. The downside is that parts are difficult to come by.
You won't be able to purchase a proportioning valve at an auto parts store. The valve has different thread pitches, depending on year, so that may be a concern with your 91. You might PM Ed Miller (ebmiller88) with your problem as he sells such items. Also, if you change gear ratios, you'll have to consider swapping the drive and/or driven gears to make the speedo read correctly.
JamesC
Engine: 383 tpi
Transmission: t5
Re: rear end 9-bolt
ok that sucks.....how much does that disk brake conversion cost for my 10bolt?? and its expensive just for parts on the 9 bolt posi rebuild.....how expensive???
thanks for that info
Old Dec 15, 2009 | 06:56 PM
JamesC's Avatar
Re: rear end 9-bolt
You should be able to sum costs from the following site:
http://www.flynbye.com/
If you choose to swap to PRB's, this should provide some answers:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
BTW, the cheapest route would probably be to find an 89-92 (or a fourthgen) disc brake rear.
JamesC
Old Dec 15, 2009 | 07:12 PM
Engine: 383 tpi
Transmission: t5
Re: rear end 9-bolt
well i thought that would be the best thing. the guys says its an 89 t/a rear with 3.27 posi pbr....i dont know what im gonna do now
ohh yea i meant to ask what is pbr???
Old Dec 15, 2009 | 08:07 PM
Engine: 383 tpi
Transmission: t5
Re: rear end 9-bolt
anyone pbr i hear alot about it but?????????
Old Dec 15, 2009 | 08:24 PM
Twin_Turbo's Avatar
Re: rear end 9-bolt
PBR is an Australian caliper brand, oem for corvettes, camaros and many other GM cars (aluminum calipers, the cast iron is all delco moraine)
Old Dec 15, 2009 | 08:33 PM
Engine: 383 tpi
Transmission: t5
Re: rear end 9-bolt
thany u everyone 4 your input .....very helpfull
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
