smog delete pulley?
Old Dec 16, 2009 | 07:19 PM
tealcamaromanrs's Avatar
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
smog delete pulley?
does ne1 know where i can get a polished alluminum (billet)smog delete pulley. i found some smog delete pulleys but not alluminum
Old Dec 16, 2009 | 07:36 PM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
Re: smog delete pulley?
why get the pulley when you can just reroute the belt and eliminate the pulley alltogether.
Old Dec 16, 2009 | 07:38 PM
Engine: 383 tpi
Transmission: t5
i just thought it might look a little weird with that big space empty....maybe fill it with a nice polished pulley and it would look like somthing was actually supposed to be in that space.
Old Dec 16, 2009 | 08:07 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Remove the A/C, swap to the 1/2 serp 1/2 V-belt setup from the IROC's (especially since you're going to TPI anyway), and it'll look mucho better!
Post #51: https://www.thirdgen.org/forums/auto...er-hood-2.html
Old Dec 16, 2009 | 09:46 PM
Damon's Avatar
FYI- there is a tech article on this board about how to remove the smog pump and install a shorter (96.8") belt with slightly different routing to keep everything else functional.
I'm one of many here who has done it. It works just fine. Visually, you don't really notice becuase the remaining bracketry down there is low in the engine bay, pretty much out of sight from above. If you want to really do a clean install it wouldn't take much to remove that bracketry entirely.
Old Dec 17, 2009 | 12:16 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have wanted to remove the bracket entirely but would lose the belt tensioner, so you would have to switch to vbelt set up, which might require a different alternator. This has been my main concern for removing the bracketry.
Old Dec 17, 2009 | 12:42 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
It would be nice to be able to run the factory bracket and use a V-belt. I wonder if there is a V-belt tensioner out there that bolts on... hmmm.
Old Dec 17, 2009 | 04:11 PM
trueburton's Avatar
you could always hack off the portion of the bracket not needed and then polish it yourself. thought about doing that myself
Old Dec 17, 2009 | 04:14 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Don't need one take the pump off and reroute the serpentine. There is a way to route it without the smog pump pulley that lets you use the same size belt.
Old Dec 17, 2009 | 05:02 PM
Engine: 383 tpi
Transmission: t5
so i guess no 1 agrees that is would just look butter with a pulley in the smog location??? i am keeping the ac and the brackets.i just dont want it to look retarded
Old Dec 18, 2009 | 06:27 PM
trueburton's Avatar
I removed my pump and didn't do anything with the bracket or the belt. just reroute it. Like stated earlier, you can't even see where the smog pump was from the top. I think it looks better w/o adding a delete pulley.
Old Dec 18, 2009 | 06:31 PM
Engine: 383 tpi
Transmission: t5
yea maybe ill do that and if i dont like it i can just add one later thanks
jaridjohn
Oct 5, 2015 07:01 AM
