oil filter/cooler
Old Dec 30, 2009 | 07:28 PM
tealcamaromanrs's Avatar
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
oil filter/cooler
i removed my oil cooler and now my oil filter will not fit on...does ne 1 know what i have to buy to get it to fit on????92 pontiac 5.7 tpi
Old Dec 30, 2009 | 07:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: oil filter/cooler
If it was the sandwich type cooler that fitted between the block and oil filter you need to remove the oil cooler adapter bolted to the block and bolt on a regular filter adapter from any SBC
Keep the adapter , it is the only way you can fit the cooler to another block if you go to sell it
Old Dec 30, 2009 | 08:01 PM
Engine: 383 tpi
Transmission: t5
its the type that gets sandwitched between the filter and the block.and two lines run off of it to a cooler.so i guess it is a sandwitch type.soo...do u know where i can get the other adapter(jegs or summit )maybe
Old Dec 30, 2009 | 08:39 PM
Engine: 383 tpi
Transmission: t5
i want to buy it but i just wannna make sure i get the right one............thanks
Old Dec 31, 2009 | 08:41 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Wrecking yard ;
oil filter adapter for any SBC and the mounting bolts (2 )
Like this
http://cgi.ebay.com/ebaymotors/Used-...Q5fAccessories
Old Jan 3, 2010 | 06:07 PM
Engine: 383 tpi
Transmission: t5
so therre is one with a bypass valve and one without........ i need the one with the bypass valve????????
Old Jan 3, 2010 | 06:12 PM
Twin_Turbo's Avatar
Depends, I prefer the ones without a bypass so the engine always gets clean filtered oil but I also have a practically burst proof System 1 washable extra long mesh oil filter, on a std. filter I wouldn't use the non bypassing kind.
Old Jan 3, 2010 | 06:41 PM
Engine: 383 tpi
Transmission: t5
so if i run a regualer oil filter i should buy one with the bypass valve??......just makin sure i understand
Old Jan 4, 2010 | 05:06 AM
Twin_Turbo's Avatar
yeah
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
