When to use longer valves?
Old Jan 11, 2010 | 07:24 AM
ssman9's Avatar
Car: 1992 Camaro RS
I am trying to decide to rebuild a set of stock heads and I am curious as to when or if you need longer than standard length valves? I'll be using comps XE268 cam (flat tappet), so there is not really that high of a lift. I will also be using the springs the Comp calls for to match the cam.
I am keeping this on the cheap since I already had these heads laying around. I hope in the near future I'll be able to get some better heads.
Old Jan 11, 2010 | 08:17 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: When to use longer valves?
You need longer valves when you use a camshaft that requires a valve spring with a higher installed height. Using longer valves also requires different length pushrods to maintain the valve train geometry.
Old Jan 11, 2010 | 03:31 PM
ssman9's Avatar
Car: 1992 Camaro RS
Thanks ... I have to check my pushrod length anyways because of the block being decked (I think .009).
Is the factory spring height is 1.70?
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
