Nothing eletrical will work
Old Jan 14, 2010 | 03:14 PM
D_Smith87's Avatar
Car: 1987 Camaro Iroc Z28
Engine: comp xr288 /budget aluminums
Transmission: TH350
Axle/Gears: 9-bolt BW 3.42 w/posi
I baught 2 new batterys, one my 1987 camaro, and one for my grandmas caprice, same battery, well anyways, i put mine in and try to get it going, and then after a few tries of cranking it, i do it another time, then it just quits, so i figured i either ruined the battery or it died, so i put in the other battery, and it's the same thing, nothing electrical will work, and my connections to the battery are good, so i have no idea what is wrong with my car.
Old Jan 14, 2010 | 03:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You may have fried the chassis power fuseable link.
Old Jan 14, 2010 | 03:58 PM
Stephen's Avatar
Car: 87 GTA
Re: Nothing eletrical will work
Sounds like you simply drained both batteries by trying to start a car that won't start.
Figure out why it won't start & your "electrical problems" will go away.
Old Jan 14, 2010 | 10:21 PM
D_Smith87's Avatar
Transmission: TH350
Yeah i asked my dad and he said it's probably the fusible link, and i am gonna go with that then too. I just baught the car, and the wiring is a complete **** job, and i just noticed a ground for the battery to the frame is disconnected, so that may be causing stuff to short out?
Old Jan 15, 2010 | 11:38 AM
five7kid's Avatar
Not short out, but inadequate path.
Old Jan 15, 2010 | 01:33 PM
D_Smith87's Avatar
Transmission: TH350
Yeah, so i just purchased all new OEM wiring to the battery which will be here monday, got a new fusible link to the starter solenoid which i will most likely install tonight, and hopefully i can get this thing running again.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
