Suction sound when opening gas cap?
Old Jan 14, 2010 | 06:44 PM
Jonboy2312's Avatar
Car: 1986 SC based 82-84 Z28 replica
Engine: 2.8 V6 MPFI
Transmission: TH-700R4
There's a very noticeable vacuum release / suction sound when I open the gas cap.
Is it supposed to happen?
I can't remember any such vacuum release sounds before... and it seems this started at about the same time as my elusive problem of losing power and suddenly running lean after extended drives.
Am I on to something here?
Old Jan 14, 2010 | 06:57 PM
Stephen's Avatar
Car: 87 GTA
Re: Suction sound when opening gas cap?
It's not suction your hearing, but rather a pressure releasing, as the "cork" (gas cap) is removed.
Perfectly normal.
Old Jan 14, 2010 | 07:02 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
vacuum is bad check valve on tank. 7 bucks
Old Jan 14, 2010 | 08:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A release is normal.
JamesC
Old Jan 14, 2010 | 09:11 PM
Jonboy2312's Avatar
Engine: 2.8 V6 MPFI
Perfectly normal.
Okay, but I could swear I feel the cap sticking - it's like air pressure inside the tank is lower than outside, not the other way around...
I'll have to investigate this some more.
Old Jan 14, 2010 | 09:24 PM
Stephen's Avatar
Car: 87 GTA
Thinking more later.....You may actually be correct, in that is was a suction.
Since the fuel pump is "suctioning" the fuel out, it could create a suction inside the tank. In that case, then yeah...Suction results.
But there should be a "whoosh" as the gas cap comes off. If there isn't one, then something is faulty.
Old Jan 14, 2010 | 10:25 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Nah, I don't think the tank would hold that much vaccum. Cause if you filled up your tank and ran it way down without opening the cap, there would be so much vaccum that I highly doubt that your fuel pump would be able to pump. I think it's all pressure that could be dependant on a couple things...like the temp of the fuel you pump in, air temp, and how warm the exhaust is and for how long. I'm sure that any variant in temp of the fuel and air in the tank would make it release pressure more or less each time you open it. I'm just guessing here though.
Old Jan 15, 2010 | 01:05 AM
You're right that the tank level would drop and be extra vacuum. Its hard on the pump and could maybe causing his lean condition after driving for a while, throws the whole computer tuning off. In the picture Ive include is from the Haynes manual, numbered 5 the ventilator plays important role to allow air and balance the pressure when negative pressure is present. The evap system draws fumes from the tank to the intake throttle body to, theres a series of check valves on the charcoal canister and under throttle or wide open it sucks. But again that shouldn't be a problem if the car is off, because the ventilator valve should compensate the pressure.. however yours doesnt
Old Jan 15, 2010 | 09:21 AM
Stephen's Avatar
Car: 87 GTA
Originally Posted by transam85dudeman
.......For example, when i get gas, if i turn the cap fast enough it can shoot as far as 4 feet.
If a gas cap shoots, that would be a case for pressure building in the tank. not vacuum. Yet your statement starts off by supporting the vacuum theory....
So are you saying there is vacuum or pressure?
Old Jan 15, 2010 | 10:42 AM
i was talking about the differences. ill delete it. thanks for pointing that dumb comment out
Old Jan 15, 2010 | 02:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You should have a working pressure relief valve on your gas tank that prevents that. Lots of cars have a pressure change when removing the gas cap though, i'm guessing the relief valves stick closed after a while.
It rarely (err, never?) effects how the car runs though.
If you want to be sure, leave the gas cap in your back seat for a few days and see if anything changes.
Old Jan 22, 2010 | 09:08 PM
Jonboy2312's Avatar
Engine: 2.8 V6 MPFI
I'll give it a try when driving back to Montreal when I take the car out of storage. If it leans out again halfway home, well, at least I'll have one possibility ruled out.
Old Jan 22, 2010 | 09:31 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
I've always had a pressure release of some kind when i remove the gas cap, never noticed a difference in the way it runs, now I'm wondering if there's something wrong.
Old Jan 23, 2010 | 01:07 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello Jason1313!!
Enjoy your pressure release, it's normal, there's nothing wrong!!
Old Jan 23, 2010 | 01:20 PM
Hello Jonboy2312!!
You have a check valve problem like transam85dudeman said in his post. Remember the gas cap is non vented, no air in = no gas out, so, there has to be a way for the air to get in there.
For $7.00 you can't go wrong!!
Old Jan 24, 2010 | 08:15 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Originally Posted by 87IROC-DAN61
Hello Jason1313!!
Thanks!!
Old Feb 2, 2010 | 01:33 AM
Rocco's Avatar
Just got my 1990 formula and it does the same thing i thought it was weird. Mine runs fine no lose of power or anything like that.
Old Feb 2, 2010 | 01:36 AM
its should really blow out not vacuum, vacuum is a sign of a bad check valve ventalator`
Old Feb 2, 2010 | 01:55 AM
Rocco's Avatar
Mine does blow out so I'm fine out is normal.
Old Feb 27, 2010 | 01:43 PM
johnc9909's Avatar
Car: 1991 Bright Red Formula 350 WS6
I have A 1991 Formula.After I've driven mine it vents off pressure with cap on sometimes. The other day I was in a drive thru with car running ,I could here it venting off pressure. I'm woundering if that's normal? Car seems to be running fine.
Old Feb 27, 2010 | 02:10 PM
johnc9909's Avatar
If it's the tank check valve does anyone know where I can get one?
Old Feb 27, 2010 | 05:02 PM
Hello johnc9909!!
If your cap is the non-vented type, which it should be, it shouldn't be venting through the cap, if it is venting through the cap you have a bad cap, change it!!
Old Feb 27, 2010 | 05:05 PM
Hello again johnc9909!!
If it's the tank vent valve, you should be able to get one from your local GM dealer, that's where I got mine last year!!
Old Feb 28, 2010 | 03:11 PM
johnc9909's Avatar
I noticed through further investigation of emission system it looks like someone put the vapor canister purge valve in opposite way. I blew into it the way they had it and would not allow air to pass to canister, turned it the other way and now when I blow on it it opens and allows air to pass. Makes sense to me vapor needs to pass to canister not be blocked the way they had it.Anyone have any thoughts?
Old Mar 1, 2010 | 07:13 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Up by the vapor canister there is the vapor canister purge valve that attaches to vac hoses that run from the canister to the gas tank. If that valve is not working right, it will cause neg pressure build up in the gas tank.
Old Mar 1, 2010 | 07:10 PM
johnc9909's Avatar
My vaper purge valve was installed by someone backwards.That should solve my problem.I also got my hands on a newFuel tank vent valve, it looks like mine has some undercoating on it and could be partially clogged.
Old Jun 6, 2021 | 01:04 PM
dtederick's Avatar
Perfectly normal.
Suggestions welcome, please!
I don't have that noise in mine & honestly can't remember the last time I did hear it. I've replaced the gas filler cap & the gasket numerous times with OEM. Still haven't heard it.
I have previously thrown the P0120 EVAP code for awhile but it turned out a vacuum line that came undone on the drivers side of the engine low in the frame.
Since I connected the hose back up I haven't thrown a code but still no pressure release sound... I have a 1998 4Runner Limited V6 3.4L 267800 miles.
Thanks ,
David
Old Jun 6, 2021 | 02:36 PM
OrangeBird's Avatar
Car: 1989 Firebird
Thanks ,
David
David, this forum is exclusively for 1982 through 1992 Pontiac Firebird and Chevy Camaro cars only. Just so you know, I'm not being mean or denying you info because your vehicle isn't a Firebird or Camaro, it's just not all that likely that anyone here is gonna know specifics about your Toyota. My best suggestion here would be to find a Toyota forum and ask your question there.
Old Jun 6, 2021 | 09:40 PM
NoEmissions84TA's Avatar
That was polite.
Old Jun 7, 2021 | 06:12 AM
Vader's Avatar
That was polite.
Yes, I was also impressed. However, it wasn't from the propriety and courtesy of our members (that's pretty common) but that the poster has a 1998 4-Runner and mentioned a vacuum line near the frame. I'm impressed that a '98 Toyo is still running, and more impressed that it still has a frame. Most of those rotted away within 5 years.
1992 Trans Am
May 10, 2023 07:19 PM
DonW
Aug 24, 2015 08:24 PM
chazman
Aug 22, 2015 02:01 PM
BurlyChev
Aug 16, 2015 09:08 PM
